-   -   Seeking for flow field (vector plot) visualization software. (http://www.cfd-online.com/Forums/main/443-seeking-flow-field-vector-plot-visualization-software.html)
Hua January 11, 1999 15:07
Hi, Folks,
I just got tons of (PIV) experimental data I'd like to plot/visualize:
The data are flow velocities in a plane in a format of 4 columns: x y Vx Vy
Just like a general CFD postprocessing, the software should be able to plot a plane vector field with vector size and color representing the magnitude of each velocity vector.
We have access to CFX, FLOW3D, and FLUENT, but has no idea whether the postprocessors can easy read the experimental data. We also like to work with some independent flow visualization software to processing the data, especially the software for Mac/Windows platform.
Any suggestion/info ?
Thank you very very much.
Hua
John C. Chien January 11, 1999 16:14
Re: Seeking for flow field (vector plot) visualization software.
You may want to take a look at the Resources/visualization section. I have been using several commerical post-processing packages (for 3-D CFD) for several years, and in general, they are very good. For your special format, you need to talk to the developer to see whether you need to write the interface software or not. ( put your data into their input format) The other way to do is to find out whether you can use the existing post-processor ( such as the one in the Fluent or alike). In either way, it shouldn't be a difficult task.
Yaping Zhu January 11, 1999 20:00
Maybe you want to try PLOT3D or TECPLOT
Zhong Lei January 11, 1999 22:49
Why do not you try to use the software, Matlab or PVWAVE? They are widely used by scientists. You may use arbitrary format of your experimental data as like as you want. They have powerful functions for postprocessing and they can also help you to analyse your data. While most of commercial CFD postprocessors are just specially designed for CFD softwares with fixed output format, and too expensive. I think many laboratory are using Matlab, because after all, they are doing experiments but not CFD.
Christoph Lund January 12, 1999 04:09
We are using Tecplot of Amtec Engineering for a similar problem of PIV-data.
Have a look at their homepage http://www.amtec.com/.
There is a chance to get a 30-days trial (evaluation) version ...
Chris
Dan Hinch January 13, 1999 12:43
Try Tecplot. I use it to post-process results from a number of different CFD packages. It's relatively inexpensive, easy to use, and will do what you have said you need.
Hua January 13, 1999 15:12
Thanks for the helps
Thanks for all helps, I'am going to get Tecplot and try.
--hua
Nikolaos kokolis January 25, 1999 12:33
I am a student (Glasgow caledonian university) and I am looking for notes about cfd,how to use and general I am intresting in the field of visualization.If you have something for me thank you very much.
