-   -   channel flow.. (http://www.cfd-online.com/Forums/main/45-channel-flow.html)
R.D.Prabhu July 14, 1998 00:22
channel flow..
Hello everybody,
I am developing a code for studying 'compressible convection ' in microchannels.
So far ( last three months) I have managed to implement Grahams - modified - two-step Lax-Wendroff scheme.
Now as a validation check ..I was trying to obtain the velocity - profiles for a fully developed flow down the channel..( including the developing profiles near the entrance..)
Can I expect such profiles as a limiting case of my code for fully compressible channel flow..? If yes then should the density fluctuations be kept minimum..? ( and take isothermal case..?)
Besides I am also faced with the problem of handling the entrance /exit for my code ..( should I use any extrapolation to update the grid-points at the inlet/outlet ) any comments/ suggestions are welcome ..
Prabhu
