-   -   contour plotts using matlab (http://www.cfd-online.com/Forums/main/4548-contour-plotts-using-matlab.html)
matlab March 20, 2002 10:04
hi fox
as this is a new plotts to me i appreciate any help. i need to plot a contour with:
x-axis is the position (-10, 10);
y-axis is the time, starting from the lowest till it reach the given time.
z-axis is the density solution.
the data generated using f90 in a file.
any matlab help please.
many thanks. xxx
Junseok Kim March 20, 2002 21:17
Re: contour plotts using matlab
Would you send your data file to me, I will write a matlab code for you.
Steven Jachec March 27, 2002 11:33
To contour in MATLAB, you x, y, and z must be matrices of the same size. There are MATLAB tools to help with this. For example,
x = -10:10 y = 0:60
then you need to meshgrid the x & y data, like [X,Y] = meshgrid(x,y);
your z data (density) should then be the same size as X & Y
type pcolor(X,Y,Z); shading interp;colorbar
Key words: meshgrid, pcolor, mesh, surf
Steven Jachec
