Fluent animation commands
Old   March 22, 2002, 03:48
Default Fluent animation commands
Khalil Bostan
Hi I'm a 3rd year Aerospace student at the University of Manchester and looking at vortex shedding from a cylinder in fluent 5.5. I'm having problems generating the tiff files in order to animate the flow. Does anyone know the commands ( solve - monitors - command) to automaticaly create a tiff file and then save the picture? any help would be much appreciated.
many thanks
Old   March 22, 2002, 04:12
Default Re: Fluent animation commands
Jonas Larsson
This belongs on the Fluent Forum.
I think that you can find the answer in the archives - use the site-wise search engine and search for "quality fluent movies".
Old   March 22, 2002, 07:36
Pei-Ying Hsieh
I am using NT, but, the steps should be the same:
1. Solve 1.1 Monitor 1.1.1 increase "Defined Commands" to 1 1.1.2 under "ON", click to put a check 1.1.3 type in macro-1 under Command 1.1.4 click "Define macro" 1.2 Do the plotting, 1.3 Slect "File" 1.3.1 Select "Hard Copy" 1.3.1.1 select tiff 1.3.1.2 select color 1.3.1.3 type in some number for Width and height under resolution. 1.3.2 click "Save" 1.4 type in filename%t.tiff 1.5 Click "End Macro"
Animation Error in Fluent Andrew FLUENT 9 October 1, 2020 16:42
How create GOOD quality animation in Fluent ? maziboss FLUENT 7 November 22, 2009 05:57
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
text shortcut commands for fluent senthil FLUENT 0 November 21, 2007 13:39
Fluent Animation FV FLUENT 0 September 6, 2004 09:18
