Test case for transitional flow
Old   March 22, 2002, 16:43
Default Test case for transitional flow
Astrid
Hi all,
For benchmarking I am looking for a test case on the transition from turbulent to laminar flow, preferably with heat transfer. I am looking for a simple geometry like a flat plate (as is used for the transition from laminar to turbulent).
Anyone? Astrid
Old   March 22, 2002, 17:08
Default Re: Test case for transitional flow
Jonas Larsson
The ERCOFTAC Transition Modelling Special Interest Group has a bunch of well documented test-cases that you can download from the web - you can find their site via the NEXUS site linked in the Resources/References section. The "ERCOFTAC Classic Collection" also contains several transitional test-cases that might be of interest.
Old   April 1, 2002, 01:16
eddy zhang
Rist U., Fasel H., 1995, Direct numerical simulation of controlled transition in a flat-plate boundary layer, Journal of Fluid Mechanics, vol.298, p.211.
Liu C., Liu Z., 1995, Multigrid mapping box relaxation for simulation of the whole process of flow transition in 3D boundary layer, Journal of Computational Physics, vol.1192), p.325.
There is another paper regarding heat transfer during transition publishsed by Fasel in JFM 1994. I could not remember volume, you may need to check if you are interested in.
Test Case: Laminar Flow Between Rotating Concentric Cylinders ebertmp OpenFOAM 4 December 3, 2012 11:54
3-D laminar flow test case Praveen. C Main CFD Forum 2 March 6, 2008 04:28
Validation case for turbulent flow Ratan Main CFD Forum 0 October 4, 2005 03:03
Flat Plate Transition Test Case Adam CFX 1 June 23, 2005 23:12
Transonic Test Case Scott Holloway Main CFD Forum 2 October 31, 2000 13:35
