Viscosity and thermal conductivity Formules
Old   April 10, 2002, 12:00
Default Viscosity and thermal conductivity Formules
CPW
Hi everyone,
Can you help me in this "near to CDF" topic?
I search for explicit expressions (formulas, laws) for both the viscosity and thermal conductivity in fluids (incompressible in general, but particularly air, water,other nearly incompressible), I mean, for instance, "exp^{T_0}*K_0.
Until now, I have only found (in Handbooks) tables with different values for these quantities for different temperatures, but I want to have something like:
"Arrhenius Law"= \mu=\mu_0*exp{T-T_0} (Valid for ???? in range of????)
Or others viscosity and thermal conductivity laws, and the fluids which can be modelised with this law.
I will need also some bibliographical references for put them in my report (Because I can't write in the Bibliography, Even if this is the truth, "Founded in the CFD Forum" .
Thank you very much for your help
CPW
Old   April 12, 2002, 13:13
Default Re: Viscosity and thermal conductivity Formules
Dean
There really isn't any general formula. Since you have tables, why not just fit those with polynomials, splines, or Pade approximants? Or one could simply input the tables and interpolate using your favorite method. For gases, the Sutherland formula often works well for fitting:
mu = A T^n / (T + B)
where mu is the coefficient of viscosity or thermal conductivity, and A, n, and B are constants that depend on which fluid you are considering. The Sutherland formula is discussed in many of the standard textbooks on fluids.
Old   April 14, 2002, 06:48
CPW
I have heared of exponentially Laws for the viscosity, and linear laws for the thermal conductivity, so these polynomials laws seems new to me. Can you give me a reference more precisely?
Thank you
Old   April 14, 2002, 12:40
Dean
This is curve fitting, not physics, and you can use whatever functions you find useful and sufficiently accurate. The "best" choice will depend upon the fluid you are modeling and the flow conditions. You might want to start with the classic "Transport Theory" by Bird, Stewart, and Lightfoot. You will find it helpful to learn some of the basic kinetic theory. Good luck with your research.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
equations for viscosity and thermal conductivity clifford bradford Main CFD Forum 9 March 21, 2014 07:24
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Effective thermal conductivity and viscosity Rashmi FLUENT 0 October 31, 2007 06:01
