FVM and FDM
Old   April 16, 2002, 03:54
Default FVM and FDM
Zhu
I have a question, hope someone here can give me answer. Thank you.
The question is: when you adopt FVM to solve governing eq. the governing eq. should be in a conservation form. Namely, for the governing eq. which is in non-conservation form, FVM method can not be employed, am I right?
Old   April 16, 2002, 05:39
Default Re: FVM and FDM
John YL
Not exactly. Mathematically you can integrate any equation with volume. For example volume intergral (a*grad(b)) can be approximated as A *volume intergral(grad(b)) where you have to get A from some sort of average of a. For fluid flow, you have mass conservation equation, momentum conservation equation, energy and species conservation equation: these equations are inherently in a conservation form unless otherwise manipulated.
Old   April 16, 2002, 07:24
Default Thank you very much!
Zhu
openfoam -> fem, fvm, fdm? tH3f0rC3 OpenFOAM 4 September 3, 2015 02:51
FDM vs FVM vs FEM in CFD analysis ck5285 FLOW-3D 1 September 1, 2009 10:51
Are the quations solved in FDM or FVM ? anon Main CFD Forum 0 December 12, 2005 22:29
Atleast 5 general Diffrences between FVM, FEM, FDM RAJ FLUENT 2 October 7, 2005 08:25
comments on FDM, FEM, FVM, SM, SEM, DSEM, BEM kenn Main CFD Forum 2 July 18, 2004 18:28
