advice needed
Old   April 28, 2002, 13:25
Default advice needed
yfy
hi there, i hope i can get advices from you guys. i have just summitted my master thesis and is waiting for viva. my master project is on internal flow simulation (not through comercial code). i am thinking about pursueing a phd in cfd but still not sure if its prospect. sorry if this happens to be a silly question: what would happen to cfd if there is a breakthrough in mathematics that solve the navier-stokes equations analytically . will cfd still plays the role as a design tool? what about the cfd engineers? please note that i'm very interested in cfd and hope to build my career on it. thank you. regards, yfy
Old   April 28, 2002, 18:40
Default Re: advice needed
Sebastien Perron
1) If you want to increase the chances of getting a good job, try to be become a specialist in an applied field (icing, combustion, turbulence, two-phase flow, etc.
2) Don't worry, I don't think there are any chances that we will be able to solve the Navier-Stokes equations analytically in the short term. These are highly non-linear equations. These equations are so complicated that is even impossible to prove the unicity of the solution for general problems.
Good luck.
Old   April 28, 2002, 22:15
yfy
thank you.
Old   April 29, 2002, 05:59
cfd
i quite agree with you sebastien, and i advice you to go for two-phase flow with a mathematical look.
Old   April 30, 2002, 07:46
JEREMY SCERRI
I have a degree in mechanical engineering and would like to continue my studues in fluid dynamics preferrably specialising in CFD. Unfortunately i cannot find a university that offers a masters degree in this topic through distance learning, any suggestions?
Rgds
Jeremy
Old   April 30, 2002, 10:31
cfd
try this
http://cfdlab.engr.utk.edu
Old   April 30, 2002, 11:25
alex
good choice
Basic advice on Importing Solid Edge model to CFX needed. stephen__white CFX 1 February 9, 2011 18:40
[snappyHexMesh] Advice needed lindsaywestraadt OpenFOAM Meshing & Mesh Conversion 2 February 18, 2010 02:20
Prism layer advice needed for port flow case MaxCFM ANSYS Meshing & Geometry 0 October 2, 2009 08:42
SUPG for 2-D Navier-Stokes advice needed.. nicole Main CFD Forum 2 November 23, 2002 00:06
advice needed! Filip Main CFD Forum 2 April 26, 2002 15:27
