multigrid solution of 2d euler equations
Old   May 16, 2002, 10:28
Default multigrid solution of 2d euler equations
jim
Hi there I am presently accelerating my flosolver (solving 2d euler equations) using multigrid. I get a fairly good early acceleration for the first classic v-cycles; however afterwards, when shifting to the fine grid (prolongation using simple averaging), I start getting oscillations that become progressively large until the residue fall saturates before reaching convergence. Can anyone tell me how to avoid the problem and how to prolong the data from coarse to fine grid inorder to avoid those oscillations. I am using a finite difference based code. thanks Jim
Old   May 19, 2002, 05:12
Default Re: multigrid solution of 2d euler equations
versi
Do you have shock wave?, if have, the prolongation should have some damping ability. If have not, maybe there is soemthing wrong with your code, your order of interpolation, your treatment of the boundary condictions on the coarse grid.
Old   May 21, 2002, 04:05
jim
hi there, thanks a lot versi, i observed that by using a direct solution on the coarse grid (that one which has run for about 700 iterations say), the oscillations disappear completely and i am also able to get some acceleration on the fine grid. can this be explained? in fact i'm using only two grid levels (with a v cycle). jim
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Delta form of Heat, Euler and NS equations RameshK Main CFD Forum 3 May 30, 2012 10:41
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 07:51
Quasi-1D Euler Equations Lost in CFD Main CFD Forum 0 March 20, 2007 20:24
Euler equations with heat conduction! salem Main CFD Forum 10 August 2, 2004 03:16
