May 21, 2002, 10:08 |
S shaped duct
hi I look for a validation case for a subsonic flow inside a S shaped duct. If it's possible, the case should be in 3D and with a speed around 100m/s. thank you for your help francois
May 21, 2002, 10:55 |
Re: S shaped duct
See if this helps any -
http://www.grc.nasa.gov/www/wind/valid/sduct/sduct.html They also give a link to the experimental data that might be of use. |
May 21, 2002, 11:01 |
Re: S shaped duct
the problem is that is in 2D, do you know some link for 3D cases?
May 21, 2002, 13:25 |
Re: S shaped duct
Francois,
I can provide you with a paper where different turbulence models were compared for the prediction of the flow in a S-shaped duct in 3D. The reference is: CH. HIRSCH & A. KHODAK (1995). 'Application of Different Turbulence Models for Duct Flow Simulation with Reduced and Full Navier-Stokes Equations'. ASME paper No. 95-GT-145, ASME TURBO EXPO' 95, Houston, TX, USA, June 5-8, 1995 Comparisons are based on some experimental LDA data from Whitelaw and Yu (1993). If you need this paper, just let me know by e-mail. Bruno |
May 21, 2002, 14:52 |
Re: S shaped duct
Actually that is a 3D case - they ran a 180 deg. section of it.
May 16, 2014, 06:44 |
Can u plz mail me. . .
#6 | |
INDIA
I am currently doing a simulation of s duct in fluent. I might find it useful for ma simulation.Mail me the document if u can adnanpmi2006@gmail.com |
Fabric Duct Modeling | Dan | FLUENT | 0 | June 30, 2008 16:00 |
Total pressure increase in the diverging duct | shiv | Siemens | 3 | February 1, 2008 04:39 |
modelling fuel cell duct in fluent | rajesh kumar tippabhotla | FLUENT | 2 | October 7, 2004 13:04 |
Stokes number for intake duct bend | Friederike | FLUENT | 0 | July 30, 2004 05:12 |
flow simulation across a small fan | jane luo | Main CFD Forum | 15 | April 12, 2004 18:49 |
