-   -   Convective boundary condition (http://www.cfd-online.com/Forums/main/4770-convective-boundary-condition.html)
STN May 24, 2002 10:48
Dear all...
I'm try to introduce convective BC, d(Phi)/dt + Uc*d(Phi)/dX = 0.0, in to my 3D-transient code. My code based on SIMPLE with staggered grid arrangement.
The problem is : solution is not converge when Convective BC is used. The simulation starts with stagnant fluid at t=0. But ths code works well for the same problem when zero gradient, d(Phi)/DX = 0.0, is applied.
Any idea or suggestion is very please to me. Thank you very much
versi May 24, 2002 23:17
Re: Convective boundary condition
The time discretization of your CBC may be a factor. Explict marching may require very small Dt. Try to use implicit one.
adarsh May 25, 2002 11:50
use the stability crieteria to determine the largest permissible Dt and run the code for Dt smaller than this
STN May 28, 2002 06:45
Thank you for your response.
Actually, in my code, implicit time discretization is used. I try to follow your suggestion by reduce Dt to very small value compare to flow time scale but it still not converge. The residual oscilates over some value.
At this point, I wonder that Am I discretize CBC correct ?
d(Phi)/dt + Uc*d(u)/dx = 0
Phi(i,n) = Phi(i,n-1) + Uc*dt/dx*(u(i,n) - u(i-1,n))
where i represents spatial index and n represents time index.
Suggestion is very please to me. Thank you...
Nicola May 28, 2002 08:43
d(Phi)/dt + Uc*d(u)/dx = 0 Phi(i,n) = Phi(i,n-1) + Uc*dt/dx*(u(i,n) - u(i-1,n)) It seems correct, but problems may arise from wrong artificial boundary conditions. Remember: in 3D subsonic flows, at inlet 4 boundary conditions and only an artificial one (total 5), at exit 4 artificial boundary conditions and only a physichal one (total 5). At wall, 4 physical boundary conditions and only an artificial one (total 5). I have no experience in convective boundary conditions, so my questions may sound silly: what is Phi? What are Uc and u? CBD seem a scalar equation, so it means that you have 1 new boundary condition (i don't know if it is at wall or at inlet or exit plane): what of the other boundary conditions (i mean no slip condition, adiabatic wall, and so on)? Be sure your system is well posed, that is that physical and artificial boundary conditions are compatible. Hope it helps,
Nicola
Enrico May 29, 2002 08:47
It's not completely clear to me what you mean for *lack of convergence*: I assume no convergence within a time-step.
I noticed that you discretize:
as:
Although we use semi-implicit discretization in our FV codes (i.e. implicit diffusion and explicit convection), we found that it is important to use the following discretization:
Phi(i,n)= Phi(i,n-1)+Uc*dt/dx*(u(i,n-1) - u(i-1,n-1))
which is implemented as a standard Dirichlet BC.
In fact it's easy to show that using a velocity field, in the representation of du/dx, that is divergence-free (i.e. that obtained at the previous time-step), you are guaranteed that your mass is globally conserved, and this prevents divergence.
Good luck
