difference between false and true transient
Old   January 13, 1999, 19:41
Default difference between false and true transient
mahesh prakash
In case of unsteady calculations one often encounters two terms namely : False transient, True transient. As I understand it, a false transient solution does not give the true transient behaviour but gives the correct final steady solution. Are there any other differences between a false transient and true transient solution?
Thanks
Old   January 21, 1999, 13:45
Default Re: difference between false and true transient
John C. Chien
There are only two types of equations1) steady-state equations, and (2) unsteady-state equations. The unsteady-state equations describe the transient behavior of the problem. Sometimes, instead of using the steady-state equations to obtain the steady-state solutions, people have tried to use the unsteady-state equations to obtain the steady-state solution. But, you never know whether this approach will lead you to the steady-state solution or not. And you also have to run the code for a long time in search of the steady-state solution. In the hope to reduce the computing time, some people try to set the time step to be a function of the grid point ( or cell ) in such a way that the time step for that cell can be increased thus the computing time reduced ( if the steady-state solution can be found in this way).
problem with Transient Thermal Ansys simox 2 ANSYS 0 January 11, 2011 14:49
Compiling OpenFOAM 1.7.1 on Ubuntu 10.10 samiam1000 OpenFOAM Installation 4 November 24, 2010 08:00
False Transient tommy CFX 1 February 9, 2006 16:47
Expert Parameter for compressible transient ioannis CFX 0 November 2, 2005 19:28
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
