Contour Drawing Algorithm
Old   June 2, 2002, 17:35
Default Contour Drawing Algorithm
Abhijit
Can anyone direct me to a paper/book that discribes algorithm to find Isolines, given a variable distribution in a domain phi(x,y) and x,y coordinates of points at which phi is known.
Thanks
Abhijit
Old   June 3, 2002, 02:54
Default Re: Contour Drawing Algorithm
adarsh
use matlab software .. adarsh
Old   June 3, 2002, 12:53
Abhijit Tilak
That's a trivial answer
Abhijit
Old   June 3, 2002, 17:26
kunal
i generally use gri for drawing vectors to color contours. it has a very nice FAQ and documentation and you can easily get scripts from there. gri can be downloaded from gri.sourceforgr.net
if you decide to use gri and have any problems using it let me know
-kunal
Old   June 4, 2002, 03:06
adarsh
kunal , can you pleas echeck the url again .. i am unable to get it..pls check the spellings.. adarsh
Old   June 4, 2002, 04:38
Rami
it is http://gri.sourceforge.net
Old   June 4, 2002, 09:57
Oleg Melnik
You can use PGPLOT. It's a fortan package working on most platforms.
http://www.astro.caltech.edu/~tjp/pgplot/
Oleg
Old   June 6, 2002, 14:19
Adarsh
is there any advantage offered by gri or PGPLOT over matlab .. can these packages support 3-d visualizations .. infact i am looking for a package for 3-d viewing of a NS-computation... thanks in advance
Adarsh
Old   June 7, 2002, 05:55
Rob Mason
The main advantage has to be that gri and PGPLOT are free and easily available online. I've never used gri but know that PGPLOT can be used for 3D visualisations. The best free software that I've found for 3D visualisations is Scilab, however. This is similar in design and use to matlab and loads of examples for 2D and 3D plotting can be found online. Scilab is also available for most platforms and in my experience is very easy to install on both windows and unix.
visit http://www.scilab.org/ for information, examples, and downloading of the software
Rob
Old   June 7, 2002, 08:20
senthil
hi you can use Plotmtv. it's a small and good package for contours. You can get it online. Just search in google for Plotmtv you'll get it. bye senthil
Old   June 7, 2002, 17:01
  #11
Jonas Holdeman
Since no one has addressed your question directly, I will give it a shot.
Efficient contour plotting was a matter of great interest maybe 20 years ago. There were a number of algorithms published. One source of published algorithms was the journal "Communications of the Association for Computing Machinery" (CACM) and the set of algorithms was referred to as the "Collected Algorithms of the ACM." Later the algorithms were published in a special journal "Transactions on mathematical software" (TOMS).
There may be better algorithms now, but the old method went something like this:
(1) Assume you have a plot package that can plot straight line segments. (2) Construct a fine grid with (x,y) coordinates over the domain on which you want to plot. (3) Evaluate the function to be coutoured at each node by computing the function or perhaps interpolating some discrete approximation. (4) Select a list of coutour levels to be plotted. (5) For each rectangle of the grid: (a) Find the largest and smallest function values on the corners. (b) Ignore the contour levels outside the range of the largest and smallest values. (c) For each acceptable contour and for each edge, find the coordinate values of the intersection of the contour level and the straight line joining the function values at the corners. (d) Plot the line segments joining coordinates with equal contour values. END
That is enough to give you contours, but you probably won't like it. You probably want to label contours, and there will be problems when a saddle point lies inside a rectangle, and there are axis labels, etc., etc., etc.
For all those details you would best follow the advice given previously. But the above description is enough to write a contouring program.
Old   June 8, 2002, 01:06
  #12
Abhijit Tilak
Hi Jonas,
Thanks for your answer. Actually I should have said "Contour Finding Algorithm" I was looking for something like this.I will look out for the references you gave. Actually I don't need to draw the contours just find the x,y position related to particular value of phi=const.This subroutine will plug in to my code. i am solving a 2-D Inverse problem in heat conduction where T(x,y) at surface of a body is known. Intermidiate step involves finding surface of phi=const, then extracting x & y coordinates corresponding to that phi=c & update the guess for unknown geometry. Anyway thanks for the answer.If you know anything further please let me know.
Abhijit Tilak.
Old   June 10, 2002, 08:47
  #13
stefan
Try http://www.astronomy.swin.edu.au/~pb...ection/conrec/
Thread Tools
Trackbacks are On
[GAMBIT] Plotting/Meshing a Contour Map (3D hill) VU_Engineer ANSYS Meshing & Geometry 6 January 28, 2014 07:59
Importing contour maps into Tecplot jcostex Tecplot 1 May 20, 2009 12:48
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai Main CFD Forum 0 April 18, 2007 03:48
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai FLUENT 0 April 13, 2007 23:17
drawing of contour plots chinthakindi Main CFD Forum 1 April 27, 2004 04:33
