What's the advantage of Pseudo-compressiblity? |
June 12, 2002, 07:34 |
I am a beginner of this field. As we know, we can use Pseudo-compressibility idea for continuity equation in the incompressibility flow instead of a pressure-correction equation, then What's the advantage of Pseudo-compressiblity? Can you give me some words or show some papers? thank you in advance.
June 12, 2002, 08:44 |
Re: What's the advantage of Pseudo-compressiblity?
There are two classical approaches to solve incopressible flows: the one using pressure correction idea and the one using pseudo-compressibility idea. The choice between the first or the latter is essentially depends on personal taste, because both work well. Anyway, I think that pseudo-compressibility is used because it's easily implemented from previously existing codes for compressible flows. So, if you have a time marching code for compressible flows, the best choice, in my opinion, is the pseudo-compressibility approach. Look for "Chorin time marching" on the net to find some papers on the subject.
Pseudo time step | Jun | FLUENT | 2 | July 14, 2016 08:17 |
pseudo Time stepping vs real time stepping | nileshjrane | Main CFD Forum | 0 | October 19, 2010 05:13 |
need a pseudo code | pritam.edke | Main CFD Forum | 0 | November 13, 2009 07:36 |
[GAMBIT] grid topology advantage | agungwp | ANSYS Meshing & Geometry | 3 | August 28, 2009 09:44 |
local time stepping and pseudo time | phil | Fidelity CFD | 0 | February 27, 2006 16:26 |
