Can a non-staggered grid Method used here?
Old   June 11, 2002, 07:20
Default Can a non-staggered grid Method used here?
lololo
Dear sir: I took pseudo-compressibility idea to process the continuity equation, Can I also used the non-staggered grid Method(By: Rhie C M ,Chow W L, 1983) now?
Old   June 12, 2002, 04:49
Default Re: Can a non-staggered grid Method used here?
versi
The pseudo-compressibility method is mostly implemented on non-staggered grid because the P and V are coupled ,the method is free of compatability constraint which is encountered in other Poisson type methods, and is flexiable in complex geometries.
Old   June 12, 2002, 07:16
lololo
Sir: Thank you for your kind answers.
Do you mean that we can use collocated arrangement for Vi and P taking no account for the oscillating pressure field which occur in SIMPLE Method?
and, can I use the central diffence scheme for discretisation of the Pressue gradient item in this case?
Old   June 12, 2002, 21:00
versi
Since you use artificial compresssiblity method, it is of hyperbolic type, and upwind scheme is preferable for all inviscid terms. A central scheme will lead to instability on collocated grid.
Old   June 13, 2002, 16:47
Jim Park
You need to be sure that you mean "collocated" and not "colocated."
Colocated means that the velocities and pressure are evaluated at the same point (as opposed to a "staggered" location scheme).
Collocated is a mathematical term - I think (and will be corrected!) that it has to do with interpolation or as method to solve ODE's.
From the context of your posts, you are probably talking about "colocated."
production term on staggered grid behzadmaha Main CFD Forum 0 April 24, 2011 16:30
staggered grid kabilan Main CFD Forum 0 March 17, 2011 07:30
nonlinear Lax-Wendroff in 2D/3D on staggered grid Jeroen Gerrits Main CFD Forum 0 August 19, 2004 17:09
Cartesian grid generation method Abu Taleb Main CFD Forum 0 April 8, 2001 12:15
Incompressible flow solver (staggered grid) J. Ehrhard Main CFD Forum 1 October 8, 1998 19:47
