on sliding grid,your suggestion needed
Old   May 22, 2002, 23:40
Default on sliding grid,your suggestion needed
J. H. Van
I want to compute 3d flow field (first one phase then transient , two phase maybe) in stirred tank using the sliding mesh method. I prefer to phoenics. But it seems that the sliding mesh method phoenics offers is not robust. Any one who has experience please give me suggestion, whether I should give phoenics up or not.
Old   June 26, 2002, 16:09
Default Re: on sliding grid,your suggestion needed
alireza ablaghdar
hi i have done a project by sliding mesh about rotor and stator interaction by fluent. i would be happy that i can help u. please explain more about your problem.
Old   July 1, 2002, 03:50
J H Van
Dear Alireza Ablaghdar: Thanks for your kindness! I want to compute the flow field in square shaped tank which is used widely in Metallurgical processing. Sliding grid method seems to be the best alternative. I want to compute by commercially cfd code such as fluent,cfx,starcd,phoenics and so on.As a beginner, I am not sure which code is the bese one. Since you had using sliding grid, would you please share your experience with me? Best regards J. H. Van
Old   July 4, 2002, 16:11
alireza ablaghdar
Dear J H Van i have used sliding mesh by fluent 5.23 and i had used gambit to meshing the model the model was a two dimensional rotor-stator interaction with unsteady behaviour. it was too complex. i dont have any information about other sofwars i would be happy to help u if u like i would be happy to know u thanks
Sliding Interface issues philippose OpenFOAM Running, Solving & CFD 7 May 5, 2014 03:13
sliding mesh, confused me, help! help! weiyang1980 FLUENT 2 September 30, 2009 21:45
Intersecting sliding interface jaswi OpenFOAM Running, Solving & CFD 0 February 15, 2008 00:07
on stirred tank your suggestion needed J. H. Fan Phoenics 3 June 18, 2002 01:01
Sliding box validation required Glenn Horrocks Main CFD Forum 1 March 1, 1999 07:00
