Combusting Two Phase Flow
I am solving combusting two phase flow (solid fuel combustion) using variable property flow. i am having difficulty in obtaining convergence. I am using two fluid model for simulating the two phase flow. Any suggestions regarding developing convergence strategy will be highly appreciated
Re: Combusting Two Phase Flow
Refer to the following article:
"Convergence Behavior For Numerical Calculations By the Euler/Lagrange Method for Strongly Coupled Phases" Gangolf Kohnen, Michael Ruger, and Martin Sommerfeld Numerical Method in Multiphaae Flows 1994 This is an ASME document with a number of FED-Vol. 185 This article talks about how to evaluate when you are converged using a statistical approach. Good luck, Jeff Franklin |
