-   -   Has anybody solved the flow in Piston-cylinder?? (http://www.cfd-online.com/Forums/main/4966-has-anybody-solved-flow-piston-cylinder.html)
Serkan July 25, 2002 03:44
Although my study field is not CFD, trying to simulate now the flow inside a piston-cylinder. I guess I have an unsteady and moving boundary case. How can I model and solve such a situation?Any experience and ideas are highly appreciated. Thanks much,
Serkan Cetin
babyface July 25, 2002 13:21
Re: Has anybody solved the flow in Piston-cylinder
I am working on a project with moving piston. If you have a commercial code in hand , it is easy; if using your own code , amy be diffcult
Jim Park July 25, 2002 14:26
Go to the University of Wisconsin web site, then look around on the engineering pages (probably mechanical, maybe chemical?) for KIVA. That's a code developed at Los Alamos for engine simulations. The U of W has done a lot of development on the code and modeling with it. Someone there should be able to tell you more about how to get it or benefit from their development.
Or do a Google search on "KIVA". You may get some hits on religious rituals of the Native Americans in the Southwest as well.
Mayank Tyagi July 25, 2002 17:46
1. Haworth and Jansen (piston cylinder in IC engine) 2. Fadlun, Verzicco et al. (JCP paper...LES with immersed boundary technique to take care of the moving piston)
Hope it helps....In case, you fail to find these papers with the given detail...I'll post the detailed reference with journal title and date of publication (I don't have it handy now).
Mayank
Serkan July 26, 2002 02:36
Thanks to all.
Serkan
Serkan July 26, 2002 02:48
Hi babyface ...We have CFD2000 here... Do not know how to solve an unsteady flow with moving boundary conditions. Trying to simulate a flow in a cylinder while the piston moves up& down. Do you have any suggestions that I should start with?
Serkan
Joern Beilke July 26, 2002 05:01
There are examples on www.adapco-online.com
