How to detect NaN's in Fortran
Old   July 25, 2002, 22:40
Default How to detect NaN's in Fortran
Wen Long
Hi,friends
I would like to know how to detect NaN's in Fortran code. I want the code to stop at the first NaN when something gets weird and then step into.
Thanks,
Wen
Old   July 26, 2002, 03:44
Default Re: How to detect NaN's in Fortran
andy
Look up "exception handling" in the documentation for your compiler. The implementation will vary from compiler to compiler.
Old   July 27, 2002, 09:05
Li Yang
Hi, if you are using F77, the following would be useful for debugging:
f77 -g -ftrap=common -O3 file.f -o file.e
dbx file.e
catch fpe
run
You will find out which value is zero !
Regards
Li
Old   July 28, 2002, 23:38
peter.zhao
If you use digital Visual Fortran, you can set the entry of floating point exception to 1 instead of 3 on project/setting/fortran/floating point.
Good luck!
Old   July 30, 2002, 22:07
x.zhang
Hi, there:
I have 2 methods:
1. To use Function IsNaN(*)
* real
it gives you a logical type
2. Do it my own way
Check if (a + 1.0) .eq. a , only NaNs will give
you a .true. answer
Good luck!
Thread Tools
Trackbacks are On
Fortran Compiler-CFX12.1 Araz CFX 11 February 14, 2012 07:36
Intrinsic Procedure 'ISNAN' in GNU FORTRAN 77 hawk Main CFD Forum 1 April 12, 2005 22:13
visual fortran Monica Main CFD Forum 1 August 28, 2004 20:45
Fortran77 or Fortran 90 Swapnil CFX 2 November 26, 2002 15:16
Why Favoring Fortran over C/C++? Zi-Wei Chiou Main CFD Forum 35 September 26, 2001 09:34
