-   -   Sutherland's Law - Helium (http://www.cfd-online.com/Forums/main/4977-sutherlands-law-helium.html)
Nashat Ahmad July 26, 2002 13:58
I was wondering if someone knew the constant in the Sutherland's relation for Helium gas.
Thanks in advance,
Nashat
Rami July 28, 2002 02:58
Re: Sutherland's Law - Helium
Hi Nashat,
I do not have exactly the data you ask for, but can suggest the following way to get it:
o Data for He may be found in http://properties.nist.gov/SemiProp/Gases/He.html
o Choose a reference temperature and its associated viscosity.
o Assume a value for the missing parameters, S.
o Use a least-squares curve fit to find the value of S that most closely follows the experimental data from NIST.
I hope this helps.
Peter July 28, 2002 15:45
I found the formula for the air:
nul=1.486*10e-6*(T^1.5)/(110.6+T)
for the Helium shouldn't be far. Take a look at Schlichting or A. Walz. "Boundary Layers of flow and Temperature". M.I.T. Press. 1969
Salvador July 29, 2002 04:55
Use Lennard-Jones potentials, more data available and more accurate
Alexandre Chatelain July 29, 2002 08:29
Here are the constants of the Sutherland law for Helium :
mu0 = 3.93267e-5 T0 = 809 C0 = 147.2
Hope it helps someone.
Alexandre Chatelain. PhD student - LES of Heat Transfer. CEA Grenoble - LEGI/Most Team - FRANCE.
Nashat Ahmad July 29, 2002 10:46
Thanks a lot for your replies. I'll give the data from NIST a try. Thanks Rami.
Nash'at
