about les
Old   July 30, 2002, 02:46
Default about les
baal
dear all. in my compressible and unstable les code,i use upwind scheme to convective item,and use LU approximate method.smagorinsky model is used.i tyied to apply cs=0.1-0.3 to the model,but the code did never to be convergent.
the flow chart of my program : 1,generate 3d mesh, 2,apply initial condition 3: main computational program (1)subroutine filter , (2)subroutine LU ,using finite difference method to solve N-S equations. (3)subroutine bounder,supply BC. (4)subroutine dynamics,integrate pressure field. 4,analyze flow field. the end thanks for your help,best wishes for you.
Old   July 31, 2002, 11:04
Default Re: about les
akangk
Dear baal:
My LU-SGS methold can go on now and the result is correct. It only fast 51s than the inital methold per time step.
It saved about 35% time.
LES basic and simple questions. dshawul Main CFD Forum 0 October 4, 2010 10:56
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 11:35
LES grid mesh L3munoz Main CFD Forum 0 April 7, 2010 05:05
LES on two phase flow Li Yang Main CFD Forum 0 May 12, 2004 08:10
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 09:58
