August 14, 2002, 08:46 |
Problems with Fluent
Hello everybody.
Could you help me to run fluent 6 under Linux RedHat 6.3 operating system. After chosing 3d and parallel for 2 processors opiton and durning reading case fluent stops to working and everything collaps. It happens, when fluent builds zones and cells suddenly stops. Fluent write informations as follows: cells.., Child process died unexpectedly from signal 11 999999 (mpsystem.c@1206): mpt_read: failed: errno=104 999999: mpt_read: error: read failed trying to read 4 bytes: Connection reset by peer EOF on command stream. The fluent process could not be started I have no idea what to do whih it. Maybe one of you had got similar problem and fixed it. Please, help. Best regards. Jacek |
August 16, 2002, 04:02 |
Re: Problems with Fluent
You should send this mail to Fluent user forum: http://www.cfd-online.com/Forum/fluent.cgi
August 16, 2002, 04:14 |
Hi, I have already did it.
Regards Jacek |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
Aeroacoustic Problem (Modeling Flow-Induced Noise Problems Using FLUENT) | cici | Main CFD Forum | 0 | September 29, 2011 14:28 |
Problems with FLUENT MPI on i7 2600K/P8P67 | TaurusASV | FLUENT | 1 | May 5, 2011 11:58 |
Does FLUENT support phase-change problems? | Danny Lim | FLUENT | 2 | August 25, 2000 22:50 |
