Parabolic eqs coupling with hyperbolic eqs
Old   August 13, 2002, 23:36
Default Parabolic eqs coupling with hyperbolic eqs
Seabank
Hello, everyone:
Now I am going on my thesis. But I meet one problem, which is how to solve the hyperbolic eqs coupling with parabolic eqs.
Thank you very much for your advice?
Old   August 19, 2002, 04:27
Default Re: Parabolic eqs coupling with hyperbolic eqs
versi
In fluid flow, always HYPERBOLIC is in time, and PARABOLIC is in space. Generally the whole eqs system is hyperbolic in t (compressible flow), you need use time marching scheme. But for incompressible flow, the nature is mainly elliptic (parabolic is a subset), then thare are pressure correction methods and artificial compressibility methods to choose.
Old   August 19, 2002, 15:10
Seabank
Thanks a lot for your reply! Maybe my last question was not clear. Would you like to read it again?
Here is my question in detail. In the PDE system, one PDE is hyperbolic, and the others are parabolic. It is 2D in space, but there are no time terms in it. How can I get convergent numerical results from this system?
Old   August 19, 2002, 23:25
versi
For the hyperbolic equation, you only use upstream condiction to march along X; for Parabolic equation, You will also need two BC in Y. Independently marching, and check if the computed two BC in Y converge. do the two BC values in parabolic come from the hyperbolic solution?
Old   August 20, 2002, 11:36
Seabank
Thank you very much! I will try it as you said. The following is the thing related to your last reply and my new questions.
The b.c. of the parabolic PDEs is the same as that of hyperbolic PDEs. But one b.c. is the result from one elliptic PDE. It means that I should solve the elliptic PDE to get one b.c. for the parabolic and hyperbolic PDEs system. Can I solve these equations together? Otherwise it is hard to get good result by the decoupling way, isn't it?
Thread Tools
Trackbacks are On
IdeasUnvToFoam Bug amp Fix benru OpenFOAM Bugs 42 November 13, 2009 08:59
one/two way coupling of DPM Angela FLUENT 3 April 28, 2008 09:29
Type of PDE: Hyperbolic or Parabolic or Elliptic? Guo Main CFD Forum 6 January 26, 2001 11:42
