Repeating the same calculations
Old   August 14, 2002, 05:59
Default Repeating the same calculations
CFD Man
Hallo, I have a rectangular block of liquid. Half of the domain (half x, e.g.) got small vertical tubes (all are of equally spaced and of same height as the domain z). Without calculating the flow around each tube, is there any way to repeat the same type of calculation quickly by solving only flow around few tubes ?
By the way, most of the tubes are along the flow (along x), the number of tubes across the flow is less !!
Cheers CFDMan
Old   August 15, 2002, 00:54
Default Re: Repeating the same calculations
david carnaga
Whats the application of the system you just described? I am just wondering.. DC
Sliding Mesh/ Repeating interface apc3161 STAR-CCM+ 0 September 4, 2009 19:31
transient calculations! lelia Siemens 9 April 14, 2008 08:33
Repeating same time steps (FSI) CJ Tune Siemens 0 February 25, 2003 20:27
Repeating same time steps (FSI). cjtune Siemens 0 February 19, 2003 23:05
Difference between two calculations Lennart FLUENT 7 November 24, 2002 01:19
