dynamic memory allocation in C++
Old   September 9, 2002, 16:48
Default dynamic memory allocation in C++
m. malik
Sorry, this is not a cfd question, but I know there are lots of people now using C++ in cfd programming.
Is there any way of dynamic memory allocation for a 2 or 3 d matrix in C++? I'm not looking for allocating the memory by defining a matrix as an array (1 d matrix), but something keeping the matrix as it is.
Thanks. - mm
Old   September 10, 2002, 04:57
Default Re: dynamic memory allocation in C++
Steve Amphlett
There is no direct support for 2d or 3d matrices in either bare C++ or it's STL (standard template library).
This is one of the reasons you'll get loads of hits if you do a web search for "C++ matrix class". Trouble is, most of them aren't quite what you want (too much or too little functionality) and people generally want cash for them.
Old   September 10, 2002, 07:10
Steve Amphlett
Correcting myself slightly...
There is no direct support for dynamically allocatable and resizeable 2d and 3d matrices in C++.
Old   September 10, 2002, 16:09
Axel Rohde
Any matrix, whether 2-D, 3-D, 4-D, or higher, is ultimately stored in RAM as a 1-D structure. Computer memory is 1-D. Only through the sophisticated use of multiple pointers can you create a higher-dimensional data structure.
Old   September 11, 2002, 01:33
Markus Lummer
In C++ you can try the following:
void main() {
double **mat2,***mat3;
int i,j,k,n1,n2,n3;
// Allocation of a 2 and 3 dimensional matrix
n1 = n2 = n3 = 10;
mat2 = new double*[n1];
mat3 = new double**[n1];
for (i=0; i<<n1>n1; i++)
mat2[i] = new double[n2];
mat3[i] = new double*[n2];
for (j=0; j<<n2>n2; j++)
mat3[i][j] = new double[n3];
// Access to matrix elements
mat2[i][j] = 1;
for (k=0; k<<n3>n3; k++)
mat3[i][j][k] = 2;
// Deallocation
delete [] mat3[i][j];
delete [] mat3[i];
delete [] mat2[i];
delete [] mat2;
delete [] mat3; }
Best regards
Markus
Old   September 11, 2002, 09:08
m. malik
Thank you very much, Markus. It works perfectly. -- Malik
Old   September 11, 2002, 21:26
Quain Tchew
I met the same problem. But mine is more difficult. In your code, the n1,n2,n3 is known by the compiler. What should I do when they are not const? For example, I read grid data from a file. But before that I don't know the number of the total vetex. Code read the size from the grid data file, maybe ni*nj*nk. Then I want to create a 3D array with size of ni*nj*nk. I tried in Visual C++ 6.0. But the operator "new" dosen't surport non-constant size.
Old   September 12, 2002, 01:12
Markus Lummer
I can't believe that the new operator does accept only constant integers as parameters. If I have to know the array sizes at compile time, I need no dynamic memory allocation at all and thus no new operator.
I do not know the Visual C++ compiler, but I use this kind of dynamic memory allocation for years with a lot of different C++ compilers on many different machines.
By the way, in my program n1,n2, and n3 are not constant. They could be read in from a file. A constant n1 is defined in C++, e.g., by
const int n1=10;
Best regards
Markus
Old   September 12, 2002, 02:15
Quain Tchew
I've crack te problem. Just like the following: ----------------------
FILE * f;
int i,j,k;
float x,y,z;
//point *points;
f=fopen("grid.dat","r");
fscanf(f,"%d %d %d",&i,&j,&k);
const int ni=i;
const int nj=j;
const int nk=k;
printf("%d,%d,%d\n",ni,nj,nk);
//read the size of grid
point ***points = (point ***)new point[ni*nj*nk]; //create 3d array. point is a class
for(k=0;k<nk;k++)
for(j=0;j<nj;j++)
for(i=0;i<ni;i++) {
fscanf(f," %f %f %f",&x,&y,&z);
Old   September 12, 2002, 02:24
Quain Tchew
these code is not needed. ---------------- fscanf(f,"%d %d %d",&i,&j,&k);
const int ni=i;
const int nj=j;
const int nk=k;
new operater does surport non-constant size
just use -------------------- int ni,nj,nk;
fscanf(f,"%d %d %d",&ni,&nj,&nk);
Old   September 12, 2002, 02:34
  #11
Quain Tchew
sorry
there are still some problems.
Old   September 12, 2002, 04:24
  #12
Steve Amphlett
This is just simple C pointer/array equivalence stuff. You'd get much more help by posting to comp.lang.c. Just don't mention you're using a C++ compiler.
If you want to make use of C++ features, make yourself a Matrix class and use STL vectors in it. Then you can do nice overloads to make your code look like your equations.
Old   September 12, 2002, 04:53
  #13
Steve Amphlett
BTW, the relevent comp.lang.c FAQ page can be found online at:
http://www.eskimo.com/~scs/C-faq/s6.html
Old   September 12, 2002, 06:52
  #14
Quain Tchew
Thanks. Now I've known how to do it.
point *** points = new point**[ni]; for (i=0;i<ni;i++) {
points[i] = new point*[nj];
for (j=0;j<nj;j++)
points[i][j] = new point[nk]; }
about numeca harmonic method Memory allocation failed uqzcpo Fidelity CFD 2 October 7, 2011 22:10
Problems with dynamic memory allocation Syed Siemens 0 July 23, 2006 12:02
Memory allocation problem shhe CFX 4 January 6, 2004 23:00
memory allocation strudl CFX 1 October 5, 2003 10:26
Dynamical memory allocation for multiblock? peter.zhao Main CFD Forum 2 May 20, 2002 04:58
