software recommendation
Old   September 20, 2002, 04:43
Default software recommendation
Lau CM
I have a project in which I need to model the 3D behavior of water tumbling into the mouth of an irregularly shaped funnel before flowing out as a full-bore flow through the other end. I would be grateful for advice on suitable software packages (commercial or otherwise) and also what special features such software must have in order to realistically model the behaviour of the water.
Thanks
Old   September 20, 2002, 09:00
Default Re: software recommendation
Jim Park
You might want to look at the Flow Science website,
http://www.flow3d.com .
Flow Science is a sponser of this website (cfd-online) and publisher of Flow3d.
There's a 3-d simulation of the flush of a toilet that you can click on the website. A quixotic - but effective - demonstration of the capabilities of that particular code.
Old   September 20, 2002, 12:10
Default CFD-ACE+
Michael Showalter
CFD-ACE+, a commercially available code from CFD Research Corporation (www.cfdrc.com), has what you need to accomplish the simulation. It is a general purpose CFD code that has a free surface or VOF(volume of fluid) model. Therefore it is capable of solving for the motion of the liquid and gas phases while resolving the free surface (including surface tension forces). Since it is a general purpose CFD code it could also be used for other applications such as conjugate heat transfer, internal/external flow of liquids and gases, chemical reactions (such as combustion or surface reactions), plus much more. Check out the inkjet application page to see the free surface modeling in action! http://www.cfdrc.com/datab/Applicati...jet/index.html
Michael Showalter
Recommendation for mesh generation software tibich72 Main CFD Forum 8 June 9, 2011 11:24
Recommendation for CFD software james15 Main CFD Forum 11 May 19, 2011 08:32
software recommendation mactech001 Main CFD Forum 0 August 30, 2010 19:13
CFD Software Recommendation 1150GSA Main CFD Forum 3 September 2, 2009 15:46
Looking for Software Recommendation Roger Peterson Main CFD Forum 3 July 5, 2000 12:44
