cfd simulation between soild & porous environment
Old   September 12, 2002, 18:42
Default cfd simulation between soild & porous environment
Latifimran Jalil
I have discovered this website today and I thing it is a wonderful idea to have this discussion board.
I am PhD researcher at De montfort university, uk. I am researching on establishing new techniques in stabilizing the airflow in radiant cooling and displacement ventilation environment.
I am currently using cfd (sabre 1) I am trying to model the effect of the air near the cool ceiling, and also looking for ideas in how to suppress the airflow in an solid to porous environment. that is a solid surface at the top (ceiling) and porous environment ( that is the area below the ceiling).
* I would be grateful if any one can suggest any ideas as how to suppress the air flow between the mentioned case.
* can some also suggest which is the best CFD model to use for air flow at low Rayleigh numbers. ( ie laminar, eddy, or kepsilon).
* can someone also tell me at what height the air will become suppressed between a solid and a porous environment (see the case mentioned above).
I will looking forward for the reply to theses questions.
thank you in advance
l jalil lijalil
Solar Radiation in OpenFOAM plainstyle OpenFOAM Running, Solving & CFD 15 July 8, 2014 04:43
Future CFD Research Jas Main CFD Forum 10 March 30, 2013 12:26
CFD plug-ins for Pro/ENGINEER users CD adapco Group Marketing Siemens 0 May 13, 2003 05:57
STAR-Works : Mainstream CAD with CFD CD adapco Group Marketing Siemens 0 February 13, 2002 12:23
ASME CFD Symposium - Call for Papers Chris Kleijn Main CFD Forum 0 September 25, 2001 10:17
