September 3, 2002, 23:25 |
curvature
Hi, there:
Does anybody know how to calculate the curvature of a convolution surface? Thanks. |
September 3, 2002, 23:32 |
sorry ,I post it again!
sorry,
The question should be: Does anybody know how to calculate the curvature of a "revolution" surface? |
September 4, 2002, 03:39 |
Re: sorry ,I post it again!
curvature in the rotational direction: 1/r, where r is the radius of the body (the distance from body surface to the rotational axis); curvature in the azimutal plane: Know the first and second derivatives first, then compute curvature according to a standard formula;
curvature = div ( N ), where is the unit normal vector. |
September 4, 2002, 07:04 |
Try using the following in Google as search terms
"curvature of a revolution surface" ......leave out the quotes when using Google. |
September 4, 2002, 23:24 |
I think you are wrong. I have thought it over before I come here for help!
1/r is not the curvature in any direction!!! e.g. When a hemi-circle rotate, a sphere is formed. I think now you know what I mean. |
September 4, 2002, 23:59 |
r is not necessarily radius of revolution. There are two principal radi of cuvature for a general surface in 3D space. Refer to a book on geometry.
September 24, 2002, 11:28 |
If you write your surface as z = f(r) where r is the radius, then the curvature is f''/sqrt(1 + f'^2) where ' = d/dr. ( If you have r = g(z) then the formulas just the same; g''/sqrt(1 + g'^2) '=d/dz ).
September 24, 2002, 12:17 |
Oops!! the square root should by a power 3/2; i.e. the cude of the square root.
Display Modes | |
strange curvature with interFoam (comparison with Brackbill work) | duongquaphim | OpenFOAM Running, Solving & CFD | 23 | July 25, 2013 02:03 |
sharp interface and curvature | yukn | Main CFD Forum | 0 | October 12, 2011 13:54 |
How to use SST Curvature Correction | mike wilson | CFX | 11 | December 19, 2010 17:04 |
Curvature Effects using the Standard K Epsilon Model | syler3321 | CFX | 2 | October 19, 2010 21:53 |
curvature correction term, material derivative of a tensor | volker | OpenFOAM Programming & Development | 7 | June 3, 2010 09:08 |
