slip flow in microchannel
Old   September 19, 2002, 23:43
Default slip flow in microchannel
Sander Nagoo
Dear sir:
I try to simulate the compressible microchannel flow ( rectangle ). The proposed model assumes the fluid is a continuum but employs a slip velocity boundary condition on the channel wall.
slip wall bc: Uwall=Kn*(dU/dy)wall
My question is, What kind of Kn I should use, mean value of a cross section or not? Thank you for your help.
best regard
Sander Nagoo
Old   September 20, 2002, 18:44
Default Re: slip flow in microchannel
Abeer
Kn is not it dimensionless number that you calculate from the flow parameters like Re??
Old   September 21, 2002, 09:16
Sander Nagoo
Dear Abeer:
Thank you for your help. But I still don't fully understand. If I want to calculate the wall velocity, should I use mean value of a corss section.
Best regard
Sander Nagoo
Old   September 24, 2002, 13:13
Raju
If you are doing this in 2-D then you would not require to take the mean value, it can be calculated by solving for u(gas)-u(wall)= Kn*(du/dy), although i think that this is not the complete equation.
Old   September 25, 2002, 01:08
Sander Nagoo
Dear Raju:
Thank you for your help. I try to compute slip wall velocity according your way(channel flow,length=3000*10^-6 m,height=1.2*10^-6 m). But I still have two questions about slip velocity.
1)dU/dy is too large, about 10^7.
2)kn=mu*sqrt(pi)/sqrt(2*rho^2*R*T),(mu=1.85*10^-5,rho=1.078,R=296.7,T=314) is too small( knout=0.055).
The slip wall velocity ( kn*dU/dy ) seems too large.What can I do about this problem? Thank you for your help.
Best regard
Sander Nagoo
Old   September 27, 2002, 13:45
Raju
the slip wall velocity cannot be that large... think this way,when you have a zero velocity when it is no-slip. Then for a small Kn number it should be low. Are you positive that (dU/dy) is so high?
Old   September 29, 2002, 08:06
Sander N agoo
Dear Raju:
Thank you for your help. Did you ever calculate this problem? Please give me some suggestion. Thank you.
Best Regard
Sander Nagoo
microchannel two phase flow with heat transfer mkj Main CFD Forum 2 September 27, 2011 21:49
Interfoam Microchannel flow parasitic velocities cfd_user2011 OpenFOAM 2 June 12, 2011 15:43
gas-liquid two-phase flow in microchannel LyngHoo FLOW-3D 7 February 3, 2011 05:07
Slip flow in UDF - Plse Help Jeerasak FLUENT 1 June 26, 2010 10:07
modelling flow in microchannel Wang FLUENT 6 October 10, 2000 09:28
