Johnson-King Turbulence model
Old   September 9, 2002, 06:56
Default Johnson-King Turbulence model
Steve Allison
I'm still hoping someone has an answer to my earlier question: can sigma(x) be less than unity, once the initial convergance criteria (with sigma=1) have been satisfied, or should sigma(x) always be greater than 1? The '87 Johnson paper is not terribly revealing. Is there only me using the JKM these days??
Thanks.
Old   September 24, 2002, 02:31
Default Re: Johnson-King Turbulence model
Sener Yilmaz
Steve, Take a look at Johnson&King, AIAA J.vol 23 pp.1684-1692. sigma(s) is 1 in equilibrium condition. JK found this value as below as 0.6 and above 1.2 for supercritical airfoil calculations in one of their test cases. Also I found this value between 0.55-1.18 in ONERA M6 AoA=5.06 calculations. sigma(s) could be below or above this eq condition...
Hope this helps, Sener Yilmaz
Adding a Turbulence Model doug OpenFOAM Running, Solving & CFD 11 May 21, 2018 13:54
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
question about turbulence model selection and sensitivity karananand Main CFD Forum 1 February 26, 2010 04:41
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 03:20
v2-f turbulence model in CFX? flga CFX 14 November 23, 2006 06:12
