2d incompressible polar problem
Old   September 26, 2002, 04:00
Default 2d incompressible polar problem
Sean Emmerson
I am having trouble solving the polar form of the Navier Stokes Equations when applied to a donut shape physical grid.
The lower boundary is moving at 10 RPM and the upper boundary is stationary.
A book recommended that I solve the momentum equations sequentially and thus I did the following.
The method used per iteration is the point by point method or Gauss seidel.
I solve the angular momentum equations first until I get a linear result. Then I solve the radial velocities. As the solution solves an oscilation appears near the stationary boundary. No amount of relaxation factors will change it.
I am using this within a SIMPLE algorithm.
Any help would be appreciated.
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 07:27
conduction problem venkataramana OpenFOAM 3 December 1, 2013 07:30
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
