-   -   How to caculate Pressure frm Streamline Fucn x,y (http://www.cfd-online.com/Forums/main/5226-how-caculate-pressure-frm-streamline-fucn-x-y.html)
ericle September 30, 2002 19:05
How to compute the pressure of an object that revealed its stream line pattern! ? thanks
Edward G. Cruz October 7, 2002 04:22
Re: How to caculate Pressure frm Streamline Fucn x
The streamline pattern around a body in a flowing fluid is generated from the velocity field. The resulting pressure field should come out from velocity field and not from the streamline pattern. I'm assuming that you started from the velocity field info here.
If not, you have to calculate velocity field first before finding out the pressure field. This is an easy procedure, but it will take some time. Go with the Flow; Edward
