Stability and convergence criteria
Old   September 30, 2002, 07:53
Default Stability and convergence criteria
Adriana
Could anyone introduce some references on convergence and stability of N-S equations for me? What's the meaning of CFL and Peclet numbers (for N-S eq.)?
Thanks!
Old   October 1, 2002, 21:11
Default somebody help me !!!!
Adriana
Thanks!
Old   October 2, 2002, 01:59
Default Re: somebody help me !!!!
Tom
Well, there is nothing wrong with the stability and convergence of the N-S eqn. Probably you refer to stability and convergence of the numerical methods/approximations for solving the N-S equations. These issues, and CFL and Peclet numbers should be described in the basic textbooks on CFD. Perhaps you can have a look there.
Tom
Old   October 2, 2002, 04:33
Nicola
I suggest you to read
C. Hirsch. NUMERICAL COMPUTATIONS of INTERNAL and EXTERNAL FLOWS,volume 1. John Wiley & Sons,
where basic concepts of stability criteria for CFD equations are exposed.
CFL (Courant, Friedrichs, Levy) number is an adimensional number used to compare temporal step and spatial step in discretized CFD equations.
Peclet number is an adimensional number used to compare advection and diffusion term in energy equation. Any basic compressible fluid dynamic book could be useful for you, but you can see http://scienceworld.wolfram.com/phys...letNumber.html.
Good luck
Old   October 2, 2002, 08:44
Default Ooops!
Nicola
May be Peclet number is the Peclet number of the cell and not the usual adimensional number I studied at Fluidynamics course. I apologize for the mistake.
Pe=ah/D
where a and D are the coefficients of the convective and diffusive term in the convection diffusion equation, h is the mesh dimension.
See for reference http://www.sjc.ox.ac.uk/scr/sobey/ib...es/node10.html
Old   October 2, 2002, 15:39
Karl
I suggest Versteeg and Malalasekera as an introduction to CFD basics.
Old   October 3, 2002, 06:08
Question.
The Peclet number tells you the relative strength of the convection term to the diffusion term. A "large" Peclet number, say Pe>2, suggests that the convectin term dominates and will help in the choice of a suitable discretization scheme. See Versteeg as suggested by Karl.
Old   October 10, 2002, 20:36
Default Re: Stability and convergence criteria
Dr.Ramadan Bassiouny
Another comprehensive book covers this issue is " Computaional Fluid Mechanics and Heat Transfer" by Tanhill, Anderson, and Pletcher Best regards
Physical Reason for stability of Implicit Schemes? radhakrishnan Main CFD Forum 26 October 3, 2023 22:05
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 07:51
Turbulence model for subsea stability, Pls. Abiodun FLUENT 1 August 23, 2007 06:52
Convergence and flow stability Prevani Kistan Main CFD Forum 3 November 12, 2004 20:23
