October 7, 2002, 17:08 |
Extapolation of forces with wall laws.
Hi. Doe's anybody know if/how it is possible to extraplate the shear forces from the values obtained with k-epsilon wall laws in order to get more accurate lift and drag force calculations.
That is, I want to be able to obtain values of the forces directly at the walls even though I have used wall laws and thus don't have access to the values at the walls. |
October 9, 2002, 03:55 |
Re: Extapolation of forces with wall laws.
I guess the friction velocity of the wall law can give the wall shear.
October 9, 2002, 11:36 |
Well as I see it by using the friction velocity to get the shear stress you only get the value at y+=50 or so, and not at the actual wall where y+=0. Maybee there's not much difference, anybody that has experience with this?
October 14, 2002, 04:46 |
u+ = sqrt(Tau_wall/rho) where Tau_wall is the shear at the wall.
Since you have y+ at point y, it comes : nu*y+/y = u+ = sqrt(Tau_wall/rho) This is under log law equilibrium hypothethis, otherwise.... Hope that helps, Sylvain |
Wall forces in interFoam | Terp | OpenFOAM Running, Solving & CFD | 14 | April 11, 2017 10:11 |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 05:44 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Wall shear forces | philippose | OpenFOAM Running, Solving & CFD | 0 | April 29, 2007 10:10 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
