October 16, 2002, 11:25 |
Fourier Chebyshev code
Hi there,
Does anyone know a free code for 3D flows in a channel using Fourier-Chebyshev discretisation ? (in Fortran if possible) Thanks |
October 22, 2002, 11:49 |
Re: Fourier Chebyshev code
Hi, Salut,
There are some codes that have been 'published' in the litterature for Fourrier and Chebyshev spectral methods. I have seen some works from Deville (Michel) mainly, a while ago already. I could try to dig out these references. I do have some 2D FOrtran codes for axi-symmetric flows in cylindrical coordinates that you could try to handle (Fourier-Chebyshev pseudospectral method of collocation, for viscous rotating compressible flow, including also additional stuff such as gravity, particles, ..). In most cases I found it better to write my own code, since Chebyshev spectral methods require a special treatment of the boundary conditions which varies according to the flow problem. Any how I could send you some subroutines in Fortran if you wish. Bonne chance, Patrick |
April 11, 2013, 06:38 |
emre
I have just seen some of the relevant posts. I dont know if you are still interested in the Fourier-Chebyshev topic, but at the moment I am trying to code the same via Matlab.
So far I only have 2d case with three different impementation methods. 1- staggered grid [Canuto-2007] 2- Coupled [Canuto-2007] 3- Splitting method [R.Peyret-Spectral methods for incomp vis flow.] --------------------------------------------------- with these codes, Couette and Poiseuille flows seem to be working fine. I have two main questions for you; 1-First of all those two cases are fully developed to validate confidently do you have any other suggestion test cases, where solutions are known. There might be many but I would assume, only few would be ok for the periodic B.C. 2-I am pretty confused by stepping up to 3d. I might need some help if you would. so if you email me back as an answer, I could give you more detailed explanation of the points I get stuck. emre137@gmail.com Thanks in advance \Emre |
The FOAM Documentation Project - SHUT-DOWN | holger_marschall | OpenFOAM | 242 | March 7, 2013 12:30 |
Debugging Unsteady 2-D Panel Method Code: Wake Modeling | RajeshAero | Main CFD Forum | 5 | November 10, 2011 05:48 |
How to make code run in parallel? | cwang5 | OpenFOAM Programming & Development | 1 | May 30, 2011 04:47 |
Open Source Vs Commercial Software | MechE | OpenFOAM | 28 | May 16, 2011 11:02 |
Small 3-D code | Zdravko Stojanovic | Main CFD Forum | 2 | July 19, 2010 10:11 |
