tidal flow simulation using finite volume method
Old   October 20, 2002, 02:34
Default tidal flow simulation using finite volume method
Jason Qiu
Hi! I am a graduate student who studies hydrodynamics. I studied the subject of Port & Coastal Engineering in my undergraduate period. I want to do some research on numerical models for tidal flow (current) of coastal areas in graduate period. I do not have much knowledge about numerical simulation. I only scanned some papers about this subject. I find the FVM (Finite Volume Method) is relatively a new method and many scholars have proved that it has a lot of merits compared with FDM (Finite Difference Method) and FEM (Finite Element Method). I have collected some materials about FVM. But most of them are about Dam-Break problems. So I am not sure if the FVM is also a good method when it comes to the tidal flow simulation of coastal areas.
I want make a program to solve the hyperbolic 2D shallow water equations (1 continuity eq, 2 momentum eqs) by FVM. I plan to consider the source terms of bottom slope and bottom friction. I plan to use the triangular mesh because it can be generated automatically. The computer language I plan to use is Matlab (Matrix Laboratory). In this language I can use the INITMESH command to generate meshes and use QUIVER command to plot fluid velocity vectors as arrows.
Because I am a beginner of this subject, I do not know if what I plan to do is reasonable and I do not know how I can do the job. I need help with this.
Thank you for your attention!
Jason Qiu
Jsnq@sina.com
Lattice Boltzmann method vs Finite Element Method and Finite Volume Method solemnpriest Main CFD Forum 3 August 12, 2013 11:00
blasius flow simulation using SIMPLE method sizyef Main CFD Forum 1 December 18, 2011 10:49
formulation of finite element&finite volume method ravindra FLUENT 0 June 27, 2007 12:04
ALE in finite volume method littlelz Main CFD Forum 5 June 21, 2003 12:50
