February 16, 1999, 03:51 |
Finite Volume
HELP !!!!! I need basic and intermediate understanding of finite volume. Do you people know where I can can get that on the net. Please help. Thank you.
Vijay. |
February 16, 1999, 10:28 |
Re: Finite Volume
(1). write down the Navier-Stokes equations in integral form . You can find it in handbooks or textbooks. ( normally, Navier-Stokes equations are written in differential form, which you can also find in handbooks and textbooks) (2). define your problem and your computational domain.(the area which you are trying to solve) (3). divide the computational domain into small volumes ( something like small cubes. this requires the so-called mesh generation) (4). apply the integral Navier-Stokes equations to each small volumes.(integrate the equation over each finite-volume) (5). apply the necessary approximations to each terms in the equation so that you can actually perform algebraic numerical integration. ( to compute each integral terms ) (6). now, for each finite volume there is a set of algebraic equations to solve. apply the boundary conditions to the complete set of equations and solve the unknowns using iterative methods, explicit methods, or implicit methods. (7). most CFD books cover finite-difference and finite-volume methods. You may want to visit a local college and check out one which matches your needs.
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
