October 25, 2002, 15:15 |
design solution needed
What curve of a centrifugal impeller blade wil produce the greatest exit velocity from the rotor for incom- pressible fluids? If the design constraint limits the vane's surface to be parallel with the rotational axis, this will produce one result. If however the width of the vane also tapers radially, other solutions are possible! Curvature in three dimensions or a helical pitch is also a consideration. The application will be for a device within which liquid circulates as in a liquid ring compressor - but for a different purpose. Not being skilled in the art, I'm looking for an idealized optimal solution mathematically described. I know this is a horrific problem in fluid dynamics, but surely something close to an answer must have been found. Any and all advice is welcome. Thank you.
grid dependancy | gueynard a. | Main CFD Forum | 19 | June 27, 2014 21:22 |
How to get the solution of last time step? | lzgwhy | Fluent UDF and Scheme Programming | 0 | September 15, 2010 22:23 |
Integration along a line during solution | DaRumpel | CFX | 16 | September 2, 2010 11:17 |
Doubt on Implicit Methods | analyse In India | Main CFD Forum | 10 | March 9, 2007 03:01 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
