October 30, 2002, 10:16 |
fluid-structure interaction
I am looking for software capable of coupling two commercial codes (Fluent and Abaqus) for the fluid-structure interaction of a heart valve. I am already aware of MpccI, MDICE, CFD-DTF but I would like to know if there was other software available?
October 30, 2002, 15:20 |
Re: fluid-structure interaction
This is for general info.
FSI for a heart valve work has been done in CFX-5 (with ANSYS I think). It has been done from the mapping of "real" artery data (similar work for lungs, baldder as well) for mechanical valves, and I have seen a case for an external heart as well in the UK. You may have a look on their site for info for and quote in your own research. |
October 30, 2002, 21:36 |
Dr. Bathe's(of MIT and FEA textbook fame) software company,ADINA has the capability I believe and I think they have some relevant examples on their website.
October 31, 2002, 07:06 |
You should try to have a look on FLUIDYN website (www.fluidyn.com). Fluidyn-FSI is a commercial code coupling finite volume and finite element methods inside the same solver. This allows for a strong and efficient coupling of the fluid and structure mechanics. Several examples and references are available on the website.
Amita |
November 4, 2002, 07:44 |
RADIOSS-CFD is a fully coupled fluid structure solver that has already been used for biomechanics simulations. You can check many examples on the web site www.mcube.fr under the applications section of M-Explicit.
Fluid structure interaction on baloons | vinz | OpenFOAM Running, Solving & CFD | 38 | September 14, 2016 13:38 |
Fluid Structure Interaction using icoFsiFoam Problems | lr103476 | OpenFOAM Running, Solving & CFD | 79 | August 7, 2014 10:30 |
Optimization or fluid structure interaction | Steve_NTUA | Main CFD Forum | 9 | August 29, 2006 04:40 |
Fluid structure interaction | tomm | FLUENT | 2 | September 16, 2004 05:33 |
Fluid Structure Interaction | Gabor Balint | FLUENT | 2 | January 5, 2000 14:08 |
