Density Problem with Chemistry Module
Old   November 1, 2002, 22:37
Default Density Problem with Chemistry Module
Steph
I am a final year engineering student doing my final project. I am having trouble with the chemistry module. I am getting incorrect results for the density and pressure. Is there a place where you can enter the densities? I would appreciate any help.
Old   November 16, 2002, 17:13
Default Re: Density Problem with Chemistry Module
jesus
hi steph, you're not giving much information!
in the implementation of chemical reactions that I'm doing, CHEMKIN provides the density (as a function of temperature, absolute pressure and molar fractions or concentrations)
estimation of density in cavitating problem rem Siemens 1 October 21, 2008 01:07
Negative density problem. compressible flow Karl Siemens 2 July 10, 2008 16:41
Problem on high density ratio in Level Set method Kai Yan Main CFD Forum 10 December 25, 2007 06:12
reg- Coupled Complex Chemistry problem Dinesh Siemens 0 July 31, 2006 14:35
Problem of PDF about density Wu Siemens 0 May 12, 2002 10:11
