NACA0012 exp.results
Old   October 31, 2002, 16:21
Default NACA0012 exp.results
muygun
Please help me, I need experimental pressure distibutions over NACA 0012-14-16 symmetric profiles at Re=5,6,9 millions. Thanks a lot.
Old   November 1, 2002, 09:08
Default Re: NACA0012 exp.results
Anders
Hi, Did you search the NASA technical report service at:
http://naca.larc.nasa.gov/reports
A lot of pdf files may be downloaded from there.
Regards Anders
Old   November 1, 2002, 11:33
muygun
Thanks Anders, I searched that web adress but I couldn't find exactly what I want especially pressure distrbutions for subsonic incompressible flows.
Old   November 5, 2002, 00:01
boling
I guess you could find that in AGARD AR-138
Old   November 9, 2002, 19:11
ZIBI
use XFOIL
Old   November 11, 2002, 16:08
James Date
J.J Thibert, M. Grandjacques, and L.H. Oham, "NACA 0012 Airfoil", AGARD Advisory Report, 1979.
N. Gregory and O.L. O'Reilly, "Low Speed Aerodynamic Characteristics of NACA0012 Airfoil Section, Including the Effects of Upper Surface Roughness Simulation Hoarfrost", NPL Aero Report 1308, National Physical Laboratory 1970.
I think one of the these reports will have what you are looking for.
Reagrds
James Date
Old   November 11, 2002, 17:40
muygun
Thanks a lot James.
Old   November 11, 2002, 17:41
muygun
Thanks a lot, Boling
[ICEM] Naca0012 tgrt18 ANSYS Meshing & Geometry 1 December 17, 2009 16:52
O-grid generator for NACA0012 Prashanth Main CFD Forum 1 October 29, 2009 23:11
NACA0012 Data as a function of Re for a VAWT model psd Main CFD Forum 1 July 31, 2009 22:04
NACA0012 experimental results. Kyung-Seok, Kim Main CFD Forum 0 March 13, 2006 05:46
I want NACA0012 simulation datas Santana Main CFD Forum 2 December 28, 2004 11:58
