convergence confirmation
Old   November 19, 2002, 04:36
Default convergence confirmation
Irfan
Hello.
After getting the solution, I am facing a difficulty in judging that the particular set of input turbulence parameters (example; Dissipation length scale & Turbulence intensity in standard K E modal), being selected are correct. For this, should I check the residuals of turbulence only or do I need to check something else.
I will appreciate your guidance in this regard
IRFAN
Old   November 19, 2002, 06:05
Default Re: convergence confirmation
mukhopadhyay
(a) there was an application-oriented publication by prof. brian thomas (metallurgical & materials transactions 1990 ? ) - interesting ! (b) one author ('forget !!) had suggested cv-wise integn of k and matching. (c) comparison with experimental results if available (d) when you say "After getting the solution", it is implied you've gone as per your checklist for 'landing' - consistency in formulation, stability, convergence (continuity, mom, k-eps), etc,etc - else it may have a crash landing.
Thread Tools
Trackbacks are On
Convergence Centurion2011 FLUENT 33 November 8, 2016 16:08
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 14:20
Convergence confirmation Irfan FLUENT 3 November 24, 2002 01:54
