Oscillation in the solution
Old   December 6, 2002, 06:45
Default Oscillation in the solution
Mark Render
Hi I'm calculating some kind of mixer flow in 2 variants. 1. 1/4 model with cyclic BC and rotating coordinate sys 2. full model with sliding mesh
In both cases give roughly the same moment around the axis of rotation. In both cases if I monitor the moment over timestep or iteration the moment oscillates with very timestep or iteration chaoticly around a mean value.
Has someone ideas what could cause this behaviour ?
Regards,
Mark
Old   December 6, 2002, 06:54
Default Re: Oscillation in the solution
Anders
What discretisation practises did you use in space and time? UD, Mars, Implicit, Crank-Nicholson?
Old   December 6, 2002, 07:27
Mark Render
Even if I use 1st order upwind in space and 1st order implicit Euler in time for the sliding grid case I get these high frequency oscillations, which seem to randomly distributed around the mean value.
regards,
Mark
Old   December 8, 2002, 08:03
Anders
Is your time step small enough not to cause your sliding motion to exceed one cell width for each sliding time step? I am not sure if this is necessary but maybe... How is your grid quality?
Thread Tools
Trackbacks are On
Integrated conjugate heat transfer solver in OpenFOAM hjasak OpenFOAM Running, Solving & CFD 170 March 2, 2016 05:20
Convergence Centurion2011 FLUENT 27 February 7, 2016 12:58
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 07:51
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Discussion about Mesh independant solution Seb Main CFD Forum 13 May 22, 2001 13:37
