December 6, 2002, 05:45 |
Oscillation in the solution
Hi I'm calculating some kind of mixer flow in 2 variants. 1. 1/4 model with cyclic BC and rotating coordinate sys 2. full model with sliding mesh
In both cases give roughly the same moment around the axis of rotation. In both cases if I monitor the moment over timestep or iteration the moment oscillates with very timestep or iteration chaoticly around a mean value. Has someone ideas what could cause this behaviour ? Regards, Mark |
December 6, 2002, 05:54 |
Re: Oscillation in the solution
What discretisation practises did you use in space and time? UD, Mars, Implicit, Crank-Nicholson?
December 6, 2002, 06:27 |
Even if I use 1st order upwind in space and 1st order implicit Euler in time for the sliding grid case I get these high frequency oscillations, which seem to randomly distributed around the mean value.
regards, Mark |
December 8, 2002, 07:03 |
Is your time step small enough not to cause your sliding motion to exceed one cell width for each sliding time step? I am not sure if this is necessary but maybe... How is your grid quality?
Integrated conjugate heat transfer solver in OpenFOAM | hjasak | OpenFOAM Running, Solving & CFD | 172 | April 13, 2023 00:42 |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
Naca 0012 (compressible and inviscid) flow convergence problem | bipulsaha | FLUENT | 1 | July 6, 2011 07:51 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Discussion about Mesh independant solution | Seb | Main CFD Forum | 13 | May 22, 2001 13:37 |
