SIMPLE
Old   December 4, 2002, 02:01
Default SIMPLE
x.zhang
I am using SIMPLE algorithm on unstructured mesh and I am using collocated variables.
On the ourflow boundary, I tried a non-reflecting boundary condition. I set du/dn=0 and dv/dn=0 and dp'/dn=const. The out normal direction is the same as u component velocity. p' is the pressure correction. It never worked for me. I change the boundary condition of p' to p'=0, but it doesn't work either.
I have to set the normal velocity and no its gradient. I don't know for imcompressible flow, whether I can set a zero gradient boundary condition for velocity.
Old   December 5, 2002, 04:57
Default Re: SIMPLE
jack
Yes. The zero gradient BC for u, v is OK. dp'/dn=0 does not work. In all the BCs, set p'=0.
Jack
Old   January 3, 2003, 15:44
Default Re: SIMPLE
Bob
I think what u want to do is set p'=0 on one edge, such as outlet, that is enough. ur problemm is ur code i think, i have writen a code and use SIMPLE successfuly to simulation packed column multiple flow . do check ur code to see if u miss something (Pataker's book)
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 17:02
The correction on pressure equation of SIMPLE algorithm in MRFSimpleFOAM solver renyun0511 OpenFOAM Running, Solving & CFD 0 November 10, 2010 01:47
Making SIMPLE converge faster Fabio Main CFD Forum 4 April 9, 2006 11:35
PISO vs. SIMPLE benedikt flurl Main CFD Forum 2 April 14, 2005 06:54
flow over a 2D cyl using SIMPLE T Main CFD Forum 1 January 27, 2001 07:32
