Convergence Crieteria for pressure terms in N-S eq
Old   January 10, 2003, 04:07
Default Convergence Crieteria for pressure terms in N-S eq
Navdeep
Hello everybody
Happy New Year
i am solving N-S equations and i encountered problems in the convergence of thye pressure terms. what is the best way to converge easy andfast. i am solving both steady and unsteady state equations. Thanks Navdeep
Old   January 13, 2003, 02:20
Default Re: Convergence Crieteria for pressure terms in N-
Manish
I solved the same by SIMPLE method, if you are using the same, then the solution will be.. For 2-D problem, then factor 'b' in pressure discratisation equation, which is generaly used for source term should be sufficiently small. for details u should see book by Patankar. For 3-D problem, there is no need for any convergance criteria, just apply four or five iterative TDMA loops over pressure equation(discratised), it will give results. I hope this can be help full. look for other people.. best of luck Happy Lohri
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
K-Epsilon model? Brindaban Ghosh Main CFD Forum 2 June 24, 2000 04:22
SOR convergence factor and error terms. R.V.Ramkumar Main CFD Forum 0 July 20, 1999 19:48
