Mesh Generation
Old   January 14, 2003, 06:00
Default Mesh Generation
Dimitri
I'd be glad to have comments on your prefered mesh generation package. Of particular interest to me is the ability to: -Read IGES surface files -Perform tets and ex meshes -Possibility to generate shell meshes (for structures) -Possibility to generate extrusion layers on surfaces
Thanks,
Dimitri.
Old   January 14, 2003, 08:14
Default Re: Mesh Generation
Farid Moussaoui
Hi Dimitri,
You have to see the Centaur System for mixed mesh generation. http://www.centaursoft.com
I presume you want to use a mixed mesh generator with Acusolve.
Farid.
Old   January 14, 2003, 08:42
Dimitri
Farid,
Thanks for your answer. Actually we need mostly to generate meshes for Radioss-cfd fluid structure coupled applications and aero-acoustics for the time being. Thanks for the input though.
Regards,
Dimitri.
Old   January 17, 2003, 12:00
Caroline
Have you looked at ICEM CFD mesh generator?
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
mesh generation for in-cylinder fluent simulation hennas ANSYS Meshing & Geometry 2 May 31, 2011 15:08
General questions on grid-based computing Adrin Gharakhani Main CFD Forum 21 June 5, 2000 13:47
