Grid Verification
Old   January 21, 2003, 10:17
Default Grid Verification
julie corish
Hi there, could anybody please explain the difference between grid verification and grid independence?
Is there any good literature available on grid verification?
Thank you, J.
Old   January 29, 2003, 21:36
Default Re: Grid Verification
Aaron
This could be an issue of semantics; it may be possible that they are intended to be the same thing.
Verification, in general, can be thought of as answering the question, "Did we solve the problem correctly?" Usually, verification is associated with software and its ability to do the intended job. For example, when a solver is verified, it means the discretizations were coded correctly and the software is expected to correctly solve the equations, provided the boundary counditions are appropriate.
Perhaps those using the terminology, "Grid verification" mean that the software used to create the grids has been verified to actually create grids.
Independence, however, is a slightly different ballgame. Grid independence means that no matter how much more we refine the grid, our solution will not get better. When this happens, we choose the largest grid size that will give us our final solution and that becomes our solution grid. The converse is true as well: we make the grid coarser and coarser until the solution is no longer consistent from grid to grid.
There is a wealth of information in the CFD literature about these topics. Check the CFD-Online References section regarding books for some places to start. Another good starting point is AIAA G-077-1998, Guide for Verification and Validation of Computational Fluid Dynamics Simulations.
Old   January 30, 2003, 08:50
Rami
As far as I understand, grid verification means verifying that the grid is admissible. By this I mean that the grid passes certain tests to verify, as some examples:
o There are no cells with negative area/volume (as may occur if care is not taken).
o Cells are not overly skewed.
o Aspect ratios are within an acceptable range.
o Cell faces are not wrapped (e.g. in quarilateral face, no face is distorted into two triangles).
There may be other requirements, specific to the the specific software you use.
The grid independence is indeed, as mentioned by Aaron, a convergence test to prove the solution achieved by a certain grid remains essentially the same on finer grids.
I hope this helps.
Old   January 30, 2003, 09:47
julie
Thanks very much to both of you, I appreciate your responses. Julie
Mapping results from CFD grid to structural grid of a free-form surface mbecker OpenFOAM Running, Solving & CFD 1 October 18, 2013 10:16
MapFields to New Grid For Extreme Grid Deformations due to Body Motion albcem OpenFOAM 0 May 5, 2009 14:17
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 08:32
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
Troubles modelling flow through a grid Hans Klaufus CFX 1 June 28, 2000 16:43
