compressible channel flow..
Old   July 17, 1998, 17:23
Default compressible channel flow..
R.D.Prabhu
Hi there ,
I am developing a code to study compressible - convection in channel-flow..
As a validation check I wanted to see if as a limiting case I can obtain the fully developed velocity profiles including the 'developing flow ' profiles at the entrance.
I am faced with the following problems:
1. for random initial conditions for the velocity (transverse component suppressed) the flow does evolve to a smooth profile ..but remains in the developing phase. I used a linear density profile to start with.
I had scaled my time with respect to the sound crossing
time. Thinking that I was not allowing sufficient time
for the flow to develop ( and length as well) I changed my time and length scaling ( L ..w.r.t channel length ..not width ..as done earlier; and time w.r.t the L/(peak velocity))
2. the flow does evolve this time ..but does not quite converge . ( I use the sum_{i,j}(v_{n} - v{n-1}) to check for convergence....any better way ..?)
Instead the convergence is destroyed by something like
a 'boundary - disturbance' emanating from the outlet.
My understanding :
since I did start without bothering about the intial flow being 'divergence less' or not...there might be the
possibility of 'incoming 'waves from the outlet..destroying the solution.
I must add that I had left the outlet boundary to evolve by itself.. ( is this wrong..?)
Now ..if I carefully choose a div.V = 0 intial state
and put the velocity - profile by hand at the outlet
( fix it I mean ..) and start with a flat - profile
at the inlet (fixed) .....Can I expect to capture
what I intended to get ..viz..all the stages of a
developing flow..in a channel.?
Does the div.V =0 state eliminate the 'waves' ?
( how do I know if these are 'numerical' or 'real'
waves..?)
any suggestions..?
thanks
Prabhu
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 18:30
Yacht in Open Channel Flow andreimour FLUENT 1 October 14, 2010 23:54
supersonic channel flow Ingo Meisel Main CFD Forum 15 August 26, 2005 07:00
Channel Flow reference Jonas Holdeman Main CFD Forum 0 September 10, 2003 15:49
compressible channel flow sky Main CFD Forum 0 December 5, 2002 09:05
