-   -   Oscillation of adaptive time step--please help (http://www.cfd-online.com/Forums/main/5715-oscillation-adaptive-time-step-please-help.html)
Sisiya February 7, 2003 16:26
Hi, there: I met with some special problem when using adaptive time step. what I did is rather simple, using smaller dt when quantity F changed fast with time, and using larger dt when F changed slower with time. But everytime when I switched the dt, I have some oscilation in F, which is not there if using uniform dt.
BTW, I used the same adaptive method for my 1D codes, it worked. but for 2D, such problem comes. does anyone know how to solve the problem? I appreciate your advice and suggestions very much!
versi February 9, 2003 03:17
Re: Oscillation of adaptive time step--please help
You are required to switch Dt smoothly in between, just as for grid.
Sisiya February 11, 2003 16:19
I have tried to change it smoothly, but seems to me no much help. BTW, I use semi-implicit scheme, so that I need not to abide by the CFL limit. Is it true?
